ticos4
#1 Posted : Tuesday, May 13, 2008 9:38:52 AM(UTC)
ticos4
Our water dispenser stop working. I checked water line and have water to the connector at bottom of fridge but from there on nothing happens. please help.:(
SublimeMasterJW
#2 Posted : Tuesday, May 13, 2008 10:34:17 AM(UTC)
SublimeMasterJW
The double water valve that your water supply connects to is probably bad. One side of that valve supply's the water to the dispenser and the other side delivers water to the ice maker. The solenoid on the water dispensing side is probably shot. Anyway it is easy to fix and you won't have to pay a dude to replace it.
ticos4
#3 Posted : Tuesday, May 13, 2008 11:15:52 AM(UTC)
ticos4
The water valve was replaced about 3 months ago. How I go about fixing the solenoid? Thanks for your help.
SublimeMasterJW
#4 Posted : Tuesday, May 13, 2008 5:36:18 PM(UTC)
SublimeMasterJW
To me if you have the water valve replaced that is about as far as you can go with it. You could do more harm than good from this point on.
