I have a universal thermostat that I would like to replace in my OLD freezer. I wanted to have directions. The thermostat came with none. I wanted to know especially about the three wires that are used to connect the thermostat. Since this is such an old freezer (1953, Model L-20), I cannot find out how to get information about it. Thank you for any insight that you can supply.
does the freezer have 3 wires to hook up or the thermostat?
The freezer has three wires, white, black and blue. The thermostat has two places to hook the wires. I think the old one had the blue and black on one and the white on the other. The old thermostat had two places too.
Did the freezer have a light in the door or top? I am thinking white is common and black runs the compressor and blue just works a light in the freezer. I may be wrong.
Yes, it has a light in the lid. It also has a light in the logo that is on the cover of the motor. It hasn't worked in years. I'm sure we just didn't change the bulb. Thanks for your information.
Thanks to you, the vintage 1953 freezer is now at 0 degrees and doing well! The thermostat installation went well. We had to change some brittle wire that was cracking. That caused us to lose the light in the lid but a flashlight will work for the next 55 years! She's ready to keep that corn frozen as soon as the garden does its work. You were great. Thanks.
Where did you get ur thermostat i need one and cant find one i have a 1954 international harvestor and am unable to find parts
