Our machine has stopped agitating. It spins and drains. I can hear it clicking seeming to switch cycles or is resetting. Any ideas?
Thanks, Brad
Take off the front cover and you will find an inverter board on the motor that gives flashing lights as diagnostic aids. This site will show you how to read them. Also, try resetting it and see if that helps. HydroWave GE Washer Repair Guide
I tried resetting before I posted, but I did not know the reset sequence. After reading your post I had the machine working 5-minutes later!
Thanks, you saved me a lot of $$
Cheers!
Great, glad that worked out and thanks for the update.
