boris_the_blade
#1 Posted : Friday, February 19, 2010 3:18:24 PM(UTC)
boris_the_blade
Hi.
My dryer is taking quite some time to heat up. Usually between 30-40 min. Seemed to happen all at once. The dryer is in great shape. Any ideas? Worth fixing?
Thanks in advance!!!!
sidfink43
#2 Posted : Monday, February 22, 2010 6:50:17 AM(UTC)
sidfink43
I would open it up and check the heating element, particularly if it is the original one. Over time the element gets brittle from heating and cooling.
If that is the problem, here is the replacement part.
Part number: AP4290655
and this fix is a lot less expensive than a new machine.
Dryers are very simple and a new basic one is no better than a 20 year old one.
