I have a GE Profiler that is not Draining. I have completed taking all the parts apart and cleaned and inspected them all. I did not find anything that would be jaming the Pump and or from working
I have put the unit in diag mode and tested auxilary pump 2L and the pump does not make a sound. of course i do not know if this is the drain pump test
Is their a way i could test that the pump is bad before i go buy one?
Thank you
THIS FORUM IS DEAD!!!!!!! |
