ellioje1
#1 Posted : Thursday, February 18, 2010 6:06:52 PM(UTC)
ellioje1
the water is running down the water line inside the freezer door going to the water dispenser. it only leaks when you get water from the door. i looked at the front bottom and found the water dripping from the line from inside, so the connector seems to be fine. so its inside the door, but im not sure how to take the door apart without tearing it up, to find what needs to be replaced.
please help
