volleyball1
#1 Posted : Thursday, February 18, 2010 7:58:36 AM(UTC)
volleyball1
My Kenmore won't move out of the clean cycle. It stayed in the clean cycle for over an hour and I had to turn it off.
My machine is connected to the hot water line so I don't think the water temp is the problem
Any suggestions?
#2 Posted : Monday, February 22, 2010 4:01:29 AM(UTC)
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154424401.pdf
Check that the water entering the machine is 120 degrees F
With a meter check the heating element and hi-limit thermostat for continuity.
