hi this washer works great and queit untill the spin cycle very noisey sounds like a bearing going bad just need a point in the right direction thank you
The bearing and seal is a fairly common problem with these. It is a time consuming but not too difficult a repair. This service manual will show you how to open up the machine and fix it. Frigidaire has good manuals with detailed instructions and good photos. http://frigidaireservicetips.co...thTumbleActionWasher.pdf
