simpleguy
#1 Posted : Monday, February 15, 2010 5:43:06 PM(UTC)
simpleguy
OK, the washer was not sitting level on its feet. With time the banging of the washer got worse and worse. I corrected the feet so the outside of the washer does not bounce around, but it still bounces horribly inside. Also, during the "slow" spin cycle, it will leak water. It did not leak during fast spin. (used fast spin to drain the water after clothes were removed. I have seen the complete parts breakdown, but unsure what balances the tub out, and will it being out of balance make it leak sometimes? Thanks in advance
simpleguy
#2 Posted : Tuesday, February 16, 2010 12:26:51 PM(UTC)
simpleguy
no ideas????
