swimoldbum
#1 Posted : Saturday, February 13, 2010 10:46:47 AM(UTC)
swimoldbum
The heating element in my Frigidaire dryer broke and grounded out. The dryer still tumbles. I am replacing the element - are there other components that might have gotten damaged that should be replaced as well?
#2 Posted : Sunday, February 14, 2010 12:57:40 AM(UTC)
Replacement parts for FRIGIDAIRE GLER642AS3 Frigidaire/dryer | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134067000.pdf
[COLOR="Blue"]The heating element in my Frigidaire dryer broke and grounded out. The dryer still tumbles. I am replacing the element - are there other components that might have gotten damaged that should be replaced as well?[/COLOR]
Cannot say.
I would check the thermostats, all should be 0 ohms.
Most likely would be the thermal limiter on the heater Item F36 in Section 1.
If you have it ripped apart you may as well check the rear bearing, belt, front glides etc for wear.
If the rear bearing is OK, I would still clean and re-grease it. Using a hi temperature grease.
Also a good time to give the interior a good cleaning including the blower wheel.
I would also clean/check the vent system.
swimoldbum
#3 Posted : Sunday, February 14, 2010 8:34:17 AM(UTC)
swimoldbum
Originally Posted by: denman Go to Quoted Post
http://manuals.frigidaire.com/p...df/Webster/134067000.pdf
Cannot say.
Ok - Thank you. I checked the thermostats and they all read 0 ohms. Based on you suggestion I will clean and re-grease the rear bearing with Hi temp grease.
swimoldbum
#4 Posted : Sunday, February 14, 2010 8:38:21 AM(UTC)
swimoldbum
Cannot say.
Ok - Thank you. I checked the thermostats and they read 0 ohms. Based on your suggestion I will re-grease the rear bearing with Hi-temp grease. Thank you for your help.
swimoldbum
#5 Posted : Sunday, February 14, 2010 8:39:26 AM(UTC)
swimoldbum
Guest (7)
Frigidaire Heating Element repair (Dishwasher Repair)
by lokewolf 4/5/2010 9:16:00 AM(UTC)
