Hello to everybody, here is my dillema. The Quiet Partner stopped while running a cycle. Water is still in it and apparently no power to the thing. I have researched the web and found that it is probably the thermo fuse. At least that is what everybody recommends. The attachment shows the melted "plastic thing" that attaches the wires to the board. There is a brown mark on the board, but nothing melted. I am just trying to figure out if I just need to change something or if the board is broken too. Since that thing can range anywhere between $120 adn $150 I just want to find out so I can decide if it is worth it. We bought the washer 03/06 and it was sold as is because it had a dent in the door. On a side note, I also read that dishwashers have a airvent or something, was not aware of it. We changed our sinkhardware about 3-4 months ago and there is no hole for a pipe now, maybe there was one before and I didn't notice. Could that have caused the malfuntion now? Also how do I get the water out of the dishwasher now? Don't want it to stink. Thanks so much for your help Stephanie rains13 attached the following image(s):
Here is another pic of the board where this plug came out of Thanks so much :) for any reply rains13 attached the following image(s):
