carolb4
#1 Posted : Friday, February 12, 2010 12:36:55 PM(UTC)
carolb4
I am trying to test different parts of the ice maker module to see if they are good, such as the heater. I have been told to use a multimeter set on RX1.
I have a digital multimeter but the scale setting doesn't have X1. So, I can't make any sense out of the readings I get. My scale is 200, 2K, 20K, 200K, etc. Can someone tell me how to test with the multimeter I have?
#2 Posted : Friday, February 12, 2010 4:57:27 PM(UTC)
Choose the 200 setting.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
