jgk2
#1 Posted : Monday, May 5, 2008 12:22:21 PM(UTC)
jgk2
I have a GE model no. JBP90A S1AA. Touchpad working ok. No fault codes. Sensor measures 1094 ohms, no short to ground. Door switch checks ok. All 3 elements check ok.Transformer voltages ok. Turn oven on in any mode, set temp. and appropriate relay energizes and sends 240 v. to appropriate element which starts to heat up, but relay only stays energized for a few seconds and then de-energizes. Shortly thereafter oven temp etc. disappears from display. Seems all that is left is the ERC. Anybody have any input?
Thanks, Greg
#2 Posted : Monday, May 5, 2008 5:26:12 PM(UTC)
Greg,
Most likely the problem is a bad electronic control. You have to call Appliance Parts Pros customer service (877-477-7278) for the right part number.
