Replaced fuse about three weeks ago, blew again. checked temperture at exhaust, cycled at 120. vent only two feet long and clear.any ideas? thank you dave
Which fuse, the unit has two of them? One on the blower and one on the heater. |
THIS FORUM IS DEAD!!!!!!! |
It's the plastic one on the blower. also I ordered the one by the model number number. thank you dave
I would check that the outside louvers on the vent open fully.
Also clean/check the blower wheel.
Check that you have control over the drying temperatures. If not you may have a grounded element.
Also may be that your cycling thermostat is shot |
