admit assist
#1 Posted : Monday, May 5, 2008 6:06:12 AM(UTC)
admit assist
The oven won't heat up at all. Burners still work, clock still works, even the self-clean will heat up. I push the oven temp button & the panel shows 75 decrees with the word "bake on" under it but does not heat up at all. Also, there is no error code on the panel. Any suggestions what to do?
#2 Posted : Monday, May 5, 2008 3:06:43 PM(UTC)
In order to provide most accurate advise we need the complete model number of the range. You can find it on the frame, behind the bottom drawer.
admit assist
#3 Posted : Tuesday, May 6, 2008 6:42:36 PM(UTC)
admit assist
Model #CRG9700CAE
#4 Posted : Wednesday, May 7, 2008 12:35:52 PM(UTC)
Remove the oven floor and the flame spreader. Unplug the Bake igniter and check for 120V to the igniter while the control calls for Bake.
If there is 120V then the igniter has to be replaced.
If there is no 120V then the control board has to be replaced.
- The part number for the igniter is AP205873
- The part number for the control board is AP204793
Here are the break down diagrams for the Maytag range Model CRG9700CAE
