Spinedocdc
#1 Posted : Monday, May 5, 2008 6:02:40 AM(UTC)
Spinedocdc
I have a 1992 Admiral side by side. Last week I tested the auto-defrost timer. Have juice up to the contacts of the heaters while on defrost. Heaters looked very corroded so I purchased another pair from you last week. Put them in last Friday. This am tested the defrost thermostat and while on defrost it tests fine. Still having ice build-up and the heaters are not coming on.
#2 Posted : Monday, May 5, 2008 3:04:06 PM(UTC)
Spinedocdc,
Did you check the heaters for continuity? If you did not yet then do it and post the results.
