GSPoulin
#1 Posted : Wednesday, February 10, 2010 5:24:49 PM(UTC)
GSPoulin
Any ideas on how to remove the motor from the blower wheel without breaking it off. It seems to be seized on.
#2 Posted : Thursday, February 11, 2010 3:17:20 AM(UTC)
http://www.applianceaid.com/wpmotor-change.html
The above may help.
Sometimes vice grips have to be used
Remember it is left hand thread.
You could try some liquid wrench on the threaded end.
Let it soak in for at least an hour.
Also be sure to clean it all off when reassembling re: it is flammable.
Often the only way to get it off is to break it.
maxman87
#3 Posted : Tuesday, April 13, 2010 5:37:43 AM(UTC)
maxman87
Denman .....exactly what is a right/left hand thread and what would one do with it. Get to your blower fan from the rear using a pair of vise grips on the motor shaft to secure a tight grip. get yourself a box or open end wrench that will stretch across the entire width of the fan, a bar extention, an adjustable wrench. midway down the wrench you should place the adjustable snug tight around the thin part of your wrench..... with the bar placed in the hole at the end of the adjust wrench now turn clockwise breaking the torque then spin the fan off. easy wasn't it. Have fun guys
#4 Posted : Tuesday, April 13, 2010 6:34:37 AM(UTC)
maxman87
Right hand thread is:
Righty = Tighty
Lefty = Loosey
Left hand thread is the opposite.
