brinan
#1 Posted : Wednesday, February 10, 2010 3:05:55 PM(UTC)
brinan
We replaced the thermo-sensor part number WPL 338906 and the igntor glows for about 5 to 10 seconds, then turns off for 30 seconds, then glows again for 5 to 10 seconds then goes off again. Can you tell me what needs to be done.
Thank you,
Brian:confused:
#2 Posted : Wednesday, February 10, 2010 5:53:10 PM(UTC)
Brian,
Make sure the gas shut-off valve for the dryer is open (there are two shut-off valves, one is inside and the other one outside the dryer).
What was the original problem?
Here are the breakdown diagrams and Replacement parts for MAYTAG LDG8410AAE Dryer - Gas | AppliancePartsPros.com
brinan
#3 Posted : Thursday, February 11, 2010 6:50:28 AM(UTC)
brinan
The dryer was tumbling with no heat coming out. Both gas valves are open. I just replaced the sensor, part # WPL 338906. Any other ideas? I also replaced the blower wheel # WPL303836 because it was rattleing and the ring-retainer #WPL9703438. Could one of the sensors in the blower chamber affect the gas from igniting?
Thank you for responding,
Brian
#4 Posted : Thursday, February 11, 2010 4:25:38 PM(UTC)
Brian,
Most likely the problem is a bad gas valve coils (on top of the gas valve).
- The coil kit Part number: AP3094251
brinan
#5 Posted : Friday, February 12, 2010 4:39:16 AM(UTC)
brinan
Thank you Gene,
That was going to be my next guess, but I didn't want to order the coil until I had some kind of confirmation.
Brian
#6 Posted : Sunday, February 14, 2010 3:10:08 PM(UTC)
You are welcome Brian,
Keep us posted.
