Hello I was able to pop off the front cover and remove the pump located on the bottom of the washeing machine. The pump has three ocktigone shape skrews along with two attatched hoses. I'm now ordering the part and when it arrives I hope I'm successful in the repair. Thank you for all your help. I'll let you know how it went when it arrives.
Originally Posted by: ReCyler  Hello,
I have a Maytage Atlantis MAV7000AWQ. For the last week it has start producing a griding noise during the agitation wash and rinse cycle. It makes NO noise during spin cycle Any advice would be appreciated.
Thanks,
ReCy I have the same problem on model MAV7200 But when I shift the tub during the wash or rinse cycle it will quit the noise for a little while. Sounds like it is loosing connection with something. We had no issues until 2 weeks ago when we replaced the drain pump. We thought the noise was the belt so we replaced it also. And it didn't fix the problem. I tried to take agitator off but it doesn't seem to be the problem. Any ideas???
