The Mfg. # is P1143429NLL. The right front burner will not work. It worked fine yesterday but today it does not work. All the others work and so does the oven. We bought this oven used so I am unsure how old it is.
is this element a two stage or dual element that i operated by main switch as well as toggle or rocker switch,problem may be burner or main switch
I do not know. When I turn on the main switch (dial) on the front panel, nothing happens. It does not even get warm when it is on high heat.
it is either switch or burner. if do not have a multimeter , checking would be a problem.
