emgconsulting
#1 Posted : Wednesday, February 10, 2010 5:37:20 AM(UTC)
emgconsulting
Have a 2 door GE fridge, 1998-2000 top/bottom freezer/fridge.
Each time the fridge turns OFF, it makes a loud bang noise (once).
This has been happening for the past 6 months but the fridge/freezer both work fine. It does not happen when starting, only when cycling off.
Any diagnosis or repair for this problem?
Model#TBX12SAXCRWH
Serial#DT920563V
#2 Posted : Wednesday, February 10, 2010 7:25:15 AM(UTC)
Replacement parts for General Electric TBX12SAXCRWH Refrigerator | AppliancePartsPros.com
Check to confirm that the compressor is making the "bang" and not just a motor mount.
If yes then probably the compressor is on it's last legs.
It may run for quite a while like this but can no longer be trusted.
The only fix is to replace the compressor and that is probably not worth doing.
I would turn it into a beer fridge so you do not loose the food in it when it does finally fail.
http://www.applianceaid.com/refrigerator.html
See Item 24
