ronke
#1 Posted : Friday, May 2, 2008 2:48:47 AM(UTC)
ronke
Freezer compartment leaking on the floor in front of door and, ice also forming on floor of freezer :(
#2 Posted : Friday, May 2, 2008 2:21:50 PM(UTC)
Most likely the problem is a clogged and/or frozen drain under the evaporator coil in the freezer.
Remove the rear panel in the freezer and defrost the drain, using a hair dryer. Run a cup of hot water to make sure it goes through.
Here are the break down diagrams for the Admiral refrigerator Model GS2726CEDW
leaking feezer (Refrigerator & Freezer Repair)
by ronke 5/2/2008 2:53:18 AM(UTC)
