Larry225
#1 Posted : Tuesday, February 9, 2010 5:11:24 PM(UTC)
Larry225
I have pulled the bolt out and the agitator won't budge. Is there a trick or a special tool to pull it out without destroying the agitator.
sidfink43
#2 Posted : Thursday, February 11, 2010 5:28:42 PM(UTC)
sidfink43
You can loop a strong thin rope under it and use a board to pry it up. Be careful, it will suddenly come loose and can smack you in the face.
Whirlpool Ultimate Care II, how do u remove Agitator Cam? (Washer Repair)
by DieselDavy 4/18/2020 5:07:51 AM(UTC)
Remove Agitator (Washer Repair)
by m179406 10/16/2015 11:36:58 AM(UTC)
Remove agitator - no lint being pumped ou (Washer Repair)
by ccumbow 10/14/2015 6:24:47 AM(UTC)
How to remove agitator on GE GTWP1800D0WW (Washer Repair)
by CCC1620 1/24/2015 10:40:44 AM(UTC)
How to remove agitator from GE washer (Washer Repair)
by jthrrt 1/1/2013 4:43:23 PM(UTC)
How to remove agitator (Washer Repair)
by just_chillin38 12/27/2012 12:12:34 PM(UTC)
How to Remove Agitator (Washer Repair)
by this_is_nascar 6/11/2012 8:32:07 AM(UTC)
by 1ottar 11/9/2011 11:44:54 AM(UTC)
how to remove Agitator on Frigidaire (Washer Repair)
by vinster 10/4/2011 11:46:19 AM(UTC)
by yooperman 7/8/2011 5:31:25 PM(UTC)
Remove agitator (Washer Repair)
by NannyBeck 5/19/2011 4:22:38 PM(UTC)
Remove Agitator - How? (Washer Repair)
by amana user 7/10/2010 9:56:14 AM(UTC)
by surgonfish 3/27/2010 6:58:12 AM(UTC)
How to remove agitator assembly (Washer Repair)
by BylerB 3/6/2010 5:41:41 AM(UTC)
how do i remove agitator (Washer Repair)
by hm7956 2/15/2010 11:47:23 AM(UTC)
