Replacement parts for MAYTAG MDBH945AWW Dishwasher - Undercounter | AppliancePartsPros.comHere is the tech sheet
http://www.servicematters.com/maytag_library/docs/16026393.pdfTry running the diagnostics.
Could be just a bad start switch. Check it with a meter, see the tech sheet.
May even be that the panel (keypad) to control board has a dirty connection, try the following cleaning procedure.
The usual way to troubleshoot this is to check the keypad, if it checks out OK then replace the control board. Still a bit of a crap shoot but your odds are better.
Connector Cleaning / CheckingUnplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
