pup71730
#1 Posted : Tuesday, February 9, 2010 7:27:54 AM(UTC)
pup71730
My Kitchen Aid KUDS1FLSS1 started to make a humming-griding noise when I start it and throughout the cycle. Any suggestions?
Hobiematt1970
#2 Posted : Friday, July 9, 2010 12:41:48 PM(UTC)
Hobiematt1970
Mine was doing the same thing. Turned out the front bearing in the motor was bad (it looked like water corrosion on the motor shaft). Motor cost was over $100. I took the motor apart (4 screws) and it uses typical skateboard bearings (608 bearing). I was able to pick up a set of 8 bearings at a local skate shop. Replaced both front and back bearings, reassembed everything, and dishwasher is quiet as the day I bought it!
Hobiematt1970
#3 Posted : Friday, July 9, 2010 12:44:46 PM(UTC)
Hobiematt1970
Mine was making a noise so loud I couldn't sleep through it. Pump motor had front bearing damage (water damage?). Took the motor apart and replaced both front and back bearings with skateboard 608 bearings ($14). Now its as quiet as the day I bought it!
