Alan K
#1 Posted : Tuesday, April 29, 2008 2:19:24 PM(UTC)
Alan K
Can anyone help me with the part I would need to put right the warning that is flashing on my freezer, :dE is flashing and in the book it says call for service..Well I would like to save the money and do it myself.
I am sure some one has the answer. You guys in this forum were great on my oven! Thanks
zoint
#2 Posted : Friday, March 5, 2010 4:26:29 PM(UTC)
zoint
My GE refrigerator did the same thing. The "de" display flashed and as you said the GE Use and Care Guide says to call for service. I checked the freezer for a few days and saw that there was no problem with food defrosting, so I figured that before I called for service I would try a simple fix. I unplugged the power cord for a few seconds and then I plugged the cord back into the power outlet. Sure enough the flashing "de" display light went out and was replaced by the NORMAL display light. I think what must of happened was that there was a temporary power failure that cause the diagnostic codes display to malfunction. Problem solved. No real problem at all in my case.http://forum.appliancepartspros...s/smilies/biggrin.gifgif
Qtip
#3 Posted : Friday, March 5, 2010 7:21:00 PM(UTC)
Qtip
DE is most likely indicating a defrost problem.. open the freezer and take a look at the back of the freezer wall - is there a bunch of frost on that back wall?
#4 Posted : Saturday, March 6, 2010 1:39:10 AM(UTC)
There also could be a temperature problem due to a defrost failure, easy to check the freezer temperature to confirm.
mryan1791
#5 Posted : Friday, April 30, 2010 3:21:54 AM(UTC)
mryan1791
Turn the fridge freezer off by the wall socket for 10 minutes ! I had the same problem but turning the fridge off sorted the problem out :o)
Guest
#6 Posted : Monday, May 15, 2023 10:33:17 AM(UTC)
Guest
Rank: Guest
United States
Thank you unplugging it waiting a few min and plugging it back in worked for me!
