Dishwasher seems to cycle correctly from control panel. Water fills normally, then when control triggers wash or rinse, recycle pump runs 15 seconds and stops. All else runs normally and wash sequence proceeds till end and pumps water out. Could this be the pump overloading or a circuit panel problem.
