On my Frigidaire model frs26rlecs2, the door has begun rubbing, making it hard to close securely. Comparing the two doors, I noticed a piece missing off the right side (refrig) door. I believe it would be called a cam riser. It's two pieces, like a washer cut in two. One piece rotates while the other stays still. This raises the door about 1/4 inch.
I cannot seem to find this part anywhere. I haven't gone back to the manufacturer yet, trying these sites first.
THIS FORUM IS DEAD!!!!!!! |
