My admiral dryer wont heat anymore after we had a power outage. Interior light won't come on.... only after cycle will light switch on. But the motor/drum all work just fine. What needs to be replaced. Phil Admiral ade700ayw asbout 3 yrs old
Here are your parts includes a wiring diagram Replacement parts for ADMIRAL ADE7005AYW Dryer - Ele | AppliancePartsPros.comSounds like you have lost half the line (L2) as they use this to power the interior light. First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts. If this does nothing. Measure the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off If OK Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal. |
THIS FORUM IS DEAD!!!!!!! |
