Where is the defrost timer on the above model?
It will be either mounted somewhere underneath where the condenser coil is, or in the control box where the refrigerator temperature control is. It will look something like this...glen65 attached the following image(s):
I was able to locate the defrost control. It is behind the front vent panel, under the freezer door, mounted on a plate. Ordered the part. Thanks for the reply. All the Best, CharleyB
