medinat23
#1 Posted : 17 years ago
medinat23
It was working fine, I had a few items in the dryer, 15 min later I removed them and put a fresh load in from the washer, and it wouldn't start. I have no clue as to why. Can somebody tell me what might be wrong? I have no prior experience with dryers and have never worked on them, but if there are a few things I can check and do myself before having to call a repair man I would appreciate it very much. I already checked my main fuse box, and there is power. I'm thinking maybe a fuse in the dryer somewhere? thanks
#2 Posted : 17 years ago
If you can post the wiring diagram (usually it's inside the control panel) it might help to guide you through the troubleshooting process. I can not find it on-line.
