My Admiral is warm ~70F on th frige. side and ~29F on the freezer side. I have cleaned the fan and compressor in the bottom of the unit. What else should I do is the Admiral dead?
Almost forgot, I should mention these things;
Luck as not been with me as my home AC has been out and the tem in my house has been running ~80F but I don't this that that would have such a dramatic effect on the frig/freezer should it?
The other day the ice maker melted the ice which later refroze.
I am adept at electrical, and other type of repair but refrigeration is not something I know anything about, please help...
Is there a large frost build-up in the freezer?
Remove the freezer back panel while running and check for frost on the evaporator coils.
Already checked no frost anywhere. Anything else to check?
I just checked one yesterday and found a bad compressor; you should get a pro to look at it, probably a bad compressor, or a bad condensing fan in the back.
The fan works and the Freezer side seems to be holding temp. but the refrigerator side in still ~70F... Grrrr this thing is driving me nuts....
