The button fell out, we ordered a new one but are unsure how to put it back in. We don't want to break it while trying. any tips or help would be appreciated. Do we need to take the panel off in order to get the button back in. please advise. thank you
One of the buttons broke on my Bosch dishwasher and I know you have to remove the fascia panel to do this and can't figure out how to get it off. I know the panel unhooks on the top & side edges by slipping a screwdriver under the edges & popping it out of the indents in the door frame but it still seems to be held in the center by the door latch & can't figure out how to undue it . If you come up with anything please let me know. Vincent Garofalo vgarofo1@optonline.net
You will need to remove the screws to seperate the inner door from the outer door, open the door and you'll see the screws around the doorliner
Whatever you do don't remove the two machine screws on each side of the inner door near the hinges. These connect the inner door to the hinge, which is under pressure when the door open.
