I installed ice maker replacement about two hours ago and have nothing. No water, no movement of the wheel/spines. When I unpluged the old ice maker it noted that the connector it plugs into was coroded and burnt (green & black). I tried everywhere to find the connected and could not so I installed individual butt connectors. They are tight. The old ice maker had water in it. It appears (don't know how to prove it) that the ice maker shorted out and took out the plug. Now I'm thinking it must have taken out something further upline. Is there a fuse / breaker in that circuit? APP Part Number: AP2984633
I removed the ice maker and tested the black/white leads feed at 119v.
