boredinoregon2
#1 Posted : Saturday, February 6, 2010 11:20:33 AM(UTC)
boredinoregon2
No line voltage to motor (no flashing light either) Checked timer --- voltage to timer but not to motor. Assume bad timer or door switch. Door switch ohmed out at 3.8 ohms. Not sure what ohm reading should be.
Thanks in advance.
sidfink43
#2 Posted : Monday, February 8, 2010 11:13:33 AM(UTC)
sidfink43
Check the fuse, this site here will show you where it is.
HydroWave GE Washer Repair Guide
