Good-day, I wonder if you can assist. I have replaced the valve assy and the water circulation motor/pump. The problem is that valve does not send water to the reservior and the circulations pump will cycle. The problem seems to come a go. I have checked the voltage at the water valve during the fill cycle and I am geting 118 volts, when I plug the valve in the voltage seems to drop and not able to function. If a bypass the ice make a plug it to 118 volts it works fine. When the system does not glitch I do get good ice. Do you have any ideas? Regards.
