M W
#1 Posted : Saturday, February 6, 2010 9:02:20 AM(UTC)
M W
Everything coming out with white film baked on. Tried "watching" thru cycle and after five minutes still said heating water. I ran hot water in sink til hottest. No water at all in dishwasher after five minutes. Could use link to manual as well as any thoughts or suggestions from pros on here. Thanks
M W
#2 Posted : Saturday, February 6, 2010 9:05:20 AM(UTC)
M W
oooh quick update...I started it again and now right away water in tub....
M W
#3 Posted : Monday, February 8, 2010 11:22:06 AM(UTC)
M W
Update: ran thru the cycle three times this weekend to try to see what I have going on. Two times the DW started fine but sat "heating the water" for 5 minutes then 10+ minutes. Each cycle seemed very long overall. Not sure how long it should last from start to finish. While it was in "delay, heating water" mode I kept opening it anc checking water temp. Never did get very hot. The one time it worked fine (but entire cycle seemed long) the water was very hot and when I opened it to check it steamed out.
Ok...any ideas? Thanks
M W
#4 Posted : Wednesday, February 10, 2010 9:32:07 AM(UTC)
M W
Bump hoping for reply
#5 Posted : Thursday, February 11, 2010 2:08:17 AM(UTC)
Could not find any tech info using the model number so the following is a bit of a guess
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/d387c10d7170b7b9852571e0006e9b3e/$FILE/4322451L.pdf
Check the thermostats with a meter they should be attached to the tub under the unit.
Check the heating element with a meter.
If it has a heater off/on button check that switch.
