having problems getting the oven door back in...
i have positioned the levers at 90 degrees but just can't seem to get it to "click" in...would appreciate any assistance to finish the task. thx a bunch..
I am assuming that the hinges are locked at the 90 degree.
As you slide the hinges into the receiver try lifting the door slightly at the same time and gently use your knee to push the bottom in. |
THIS FORUM IS DEAD!!!!!!! |
