lych
#1 Posted : Thursday, April 24, 2008 4:28:37 PM(UTC)
lych
Check power outlet -ok, found out heating element cut into several pieces (some even stuck to the metal housing!). Which parts were likely affected that i need to check and replace. Specific model diagram and parts number will be very much appreciated....tnx
#2 Posted : Friday, April 25, 2008 4:42:11 PM(UTC)
lych,
Most likely you have to replace: the heating element (#14 on the break down diagram), the hi-limit thermostat (#34 on the break down diagram), the thermal fuse (#59 on the break down diagram) and the cycling thermostat (#42 on the break down diagram).
- The part number for the heating element is AP3094254
- The part number for the hi-limit thermostat is AP3131941
- The part number for the thermal fuse is AP3132867
- The part number for the cycling thermostat is AP3131939
