Range will randomly display error code E2/F3. The broiler element will automatically come on. I've turned power off to reset. I've tested the sensor and it checks out at 1079 ohms @ 68*. Next step control panel?
Most likely the problem is a bad control board.
In order to provide the right part number I need the rest of the model number (one more letter and one more digit) and the color of the control panel.
