robvinceint
#1 Posted: : Friday, February 5, 2010 2:35:41 PM(UTC)
robvinceint
I opened my dishwasher and found water in the bottom it slowly drained overnight took out the shopvac and cleaned the rest. I checked and didnt see any upstructions. My main concern is I have no power to the control panel how can i check to make sure power is going to the panel.:confused:
#2 Posted : Saturday, February 6, 2010 12:50:34 AM(UTC)
Replacement parts for WHIRLPOOL DU930PWPQ2 Undercounter Dishwasher | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535431.pdf
Check it with a meter for voltage.
If you have 120 volts in the wall plug or wire nuts, depending on how it is installed. Then remove power from the unit, remove the door's inner panel and check the thermal fuse (Item 4 in Section 1). Should be 0 ohms if not replace it. Be sure to use the new harness.
