MD110772
#1 Posted : Friday, February 5, 2010 10:59:28 AM(UTC)
MD110772
oven was working fine then all of the sudden tripped breaker/ reset breaker after voltmeter reading correctly at receptacle. stovetop working, oven digital readout is working, but oven bake/and broiler elements not working. manual leads to e.o.c, aka timer clock, just want to know if im heading in the right direction and is it a matter of simple plug and play.
#2 Posted : Saturday, February 6, 2010 1:58:24 AM(UTC)
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316417705.pdf
Yes it could be the EOC but I would unplug it, open the unit up and check that the wires from the EOC to the elements are OK.
Also I am assuming the preheat light comes on and does not go off.
aperrodin
#3 Posted : Sunday, July 3, 2011 8:09:55 PM(UTC)
aperrodin
http://manuals.frigidaire.com/p...pringfield/316417705.pdf
How can I test my eoc?? I am not getting the bake or broil element to work. I have checked the element connections and circuit breaker. Please advise, I'd like to cook for the 4th:o
#4 Posted : Tuesday, July 5, 2011 12:23:56 AM(UTC)
aperrodin
I have been out at the cottage for the weekend so did not see your post.
Please start your own thread using Post New Topic at the start of this forum section. Just adding to a different model post will confuse things.
Also include a make and model number.
Units can very greatly when it comes to how they are wired.
