bunniez
#1 Posted : Tuesday, August 21, 2007 11:38:09 AM(UTC)
bunniez
I just have a quick question that I hope someone can answer. My husband put a new element in my oven. It worked great after that, but then we put a new bulb in the oven and realized how dirty it was, so my husband used the vacuum in the oven to suck out some of the stuff in the bottom and I think he knocked the connection loose. It was hard for him to get it hooked on to the wires in the back of the stove to begin with. Some people here at work were telling me about some kind of jumper connectors or something you can get when the wires arent long enough to connect easily to the element connector. Can someone tell me what this item is called and where it can be purchased?
Admin / APP Team
#2 Posted : Tuesday, August 21, 2007 3:25:16 PM(UTC)
Admin / APP Team
Rank: Administration
Nothing that I know of. If I had to deal with this problem and the wires were too short, I'd pull the oven out, remove the back panel and use 14 gauge hi-temp wires and hi-temp terminals to make the exsisting wires longer.
IMPORTANT: If one or more wires came off the oven element, DO NOT USE the oven at all. Turn off the power to it right away and keep it off until this is fixed.
Is it safe? Can I use electric oven again after POP noise and breaker tripped? (Oven Repair (including Ranges and Cooktops))
by Guest 3/2/2024 5:41:59 AM(UTC)
KitchenAid builtin electric oven (Oven Repair (including Ranges and Cooktops))
by Guest 1/10/2024 5:07:18 PM(UTC)
F2 Error Code on GE Electric Oven (Oven Repair (including Ranges and Cooktops))
by Guest 9/11/2023 6:33:44 PM(UTC)
Whirlpool Electric Oven Convect Broil (Oven Repair (including Ranges and Cooktops))
by Guest 8/12/2022 8:27:28 AM(UTC)
GE Electric Oven - Won't stay on (Oven Repair (including Ranges and Cooktops))
by tstwingirls@yahoo.com 2/23/2022 3:51:15 PM(UTC)
Frigidaire electric oven model number PLEF489CCF (Oven Repair (including Ranges and Cooktops))
by Guest 7/25/2021 4:06:10 AM(UTC)
LG LSE3092 Electric Oven (Oven Repair (including Ranges and Cooktops))
by cycle70 4/10/2021 11:11:00 AM(UTC)
GE Profile electric oven will not turn on (Oven Repair (including Ranges and Cooktops))
by toddlamp 3/31/2021 7:03:39 PM(UTC)
ge tru-temp electric oven (Oven Repair (including Ranges and Cooktops))
by Guest 3/17/2021 4:26:18 PM(UTC)
Monogram electric oven not heating (Oven Repair (including Ranges and Cooktops))
by Norploc 2/26/2021 12:56:03 PM(UTC)
ZLINE RA36 ELECTRIC OVEN (Oven Repair (including Ranges and Cooktops))
by AndyGray 1/21/2021 5:13:45 AM(UTC)
Help! GE Profile Electric Oven PT916SMSS (Oven Repair (including Ranges and Cooktops))
by Marsa 5/9/2020 8:36:48 AM(UTC)
Electric oven panel issue? (Oven Repair (including Ranges and Cooktops))
by nhreprops 11/23/2019 10:59:26 AM(UTC)
Can I use the electric oven without the broiler heating element? (Oven Repair (including Ranges and Cooktops))
by Al Thumbs 3/16/2019 10:53:19 AM(UTC)
KitchenAid Electric Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by frosini 10/1/2018 7:23:00 AM(UTC)
