Does anyone have an idea as to why my ice maker (on my GE side-by-side) would be leaking on the INSIDE of the freezer? It has a slow drip somewhere around where this little white hose comes in and attaches to the ice maker unit on the inside of the freezer. Is this a common occurrence with these units...especially with it being 10 years old? Do you know of any DIY replacement kits that I can handle this project? Hopefully it is fairly inexpensive fix! Any tips or advice would be greatly appreciated.
Thanks! Brian
If the tube you're talking about is the water fill hose for the Ice Maker, then you'll need a new inlet valve assembly. It's leaking by.
