Mike Boeve
#1 Posted : Thursday, February 4, 2010 12:27:50 PM(UTC)
Mike Boeve
I have a 3-cord plugin and need to replace with a 4-cord plug-in. Where does the ground wire attach?
#2 Posted : Thursday, February 4, 2010 7:48:57 PM(UTC)
You have to first disconnect the ground strap the connects the center connector on the unit's terminal strip to the units frame.
The line cords ground wire then connects to the units frame.
The following may also help
http://www.applianceaid.com/general.html#3to4
