fgroce
#1 Posted : Tuesday, April 22, 2008 5:40:10 PM(UTC)
fgroce
I've changed the thermastat and the pilot light safty valve. When the oven nob is turned on the pilot light does not get bigger and thoe oven gas wont come on. I have even tride heating the valve tube and the gas want come on.
#2 Posted : Wednesday, April 23, 2008 3:34:36 AM(UTC)
There should be an adjustment for the pilot lite on the thermostat body, just turn it up and make sure the hottest point of the flame is in the sensor wire.
fgroce
#3 Posted : Wednesday, April 23, 2008 5:36:38 PM(UTC)
fgroce
Thanks but I did that. It is barly on will not adjust up. When you turn on the gas burner is't the pilot suposed to get bigger. Don't forget it has a new thermostat and safty valve.
#4 Posted : Thursday, April 24, 2008 12:44:44 AM(UTC)
Try cleaning the capillary line that feeds the pilot lite.
