kmagrini
#1 Posted : Tuesday, April 22, 2008 7:17:36 AM(UTC)
kmagrini
All four of my top burners do not light. When I turn the knobs into the 'ignite' position, I do NOT hear a clicking noise. I have to light each burner with a match, then they work perfectly. The oven lights and works perfectly, this poblem is with the top range burners only.
What part(s) do I need to replace to fix this?
#2 Posted : Tuesday, April 22, 2008 5:21:33 PM(UTC)
Most likely the problem is a bad spark module (#5 on the control panel break down diagram).
- The part number for the spark module is AP3672576
Here are the break down diagrams for the Whirlpool range Model SF367LEKQ0
