frankblumberg
#1 Posted : Monday, February 1, 2010 8:20:15 AM(UTC)
frankblumberg
how do i replace heating element in affinity dryer i need diagram
I'm not sure element is bad the dryer works but there is no heat
#2 Posted : Tuesday, February 2, 2010 2:16:53 AM(UTC)
Replacement parts for FRIGIDAIRE AEQ7000ES1 Frigidaire/dryer | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134682200ts_wd_EFS.pdf
This should also help
http://frigidaireservicetips.com/pdfs/492_AffinityDryerManual.pdf
Try running the diagnostics to see if you can get an error to come up.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 15 ohms approximately.
How do i replace heating element (Dryer Repair)
by jtrapp12 10/20/2012 1:04:02 PM(UTC)
how do i replace heating element or fuse (Dryer Repair)
by George1S 8/9/2009 10:00:51 AM(UTC)
