2 Pages<12
yorkc
#11 Posted : 17 years ago
yorkc
Sounds like the type of microwave that I have. Sounds like the problems I'm having too. No heat, loud buzzing, everything else normal. Any insight as to where I should look for the model number on this thing? I've been all over it, and under panels with no luck. They're usually quite easy to find. Hope it's not on a data plate that may have come loose and subsequently lost. Thanks...
traum
#12 Posted : 17 years ago
traum
Seems I have the same microwave. Over the range spacemaker XL 1800.
Everything seems to work fine. Just will NOT heat. I used it last night and have seen no symptoms of problems. It just quit heating.
I had the humming noise too and GE replace something last year.
It cost $80 to have GE come out and look. I just called. Plus parts and labor.
How much could it wind up costing???
traum
#13 Posted : 17 years ago
traum
model # could be JVM1870SK03
mine is from nov 06
traum
#14 Posted : 17 years ago
traum
If anyone wants to sell off the turntable plate from one of these non workig microwaves I'll take it. I will probably wind up getting my no heater fixed, but I broke the plate. What a day...
spacesaver 1800XL
This website wants $50.00 for one!!!!!!!!!!!!!!!!!!!!!!!
lrod
#15 Posted : 16 years ago
lrod
This is the same exact thing that is happening with my spacemaker. It's over 5 years old. Light works, turntable turns, digital clock works, except it won't heat. It doesn't sound like it used to, there is an extra humming sound, but I do remember the night before I was popping popcorn and it sounded like the microwave popped, like when you put something metallic in it. Next morning it wasn't working anymore. All I want to know is whether I should call me someone to fix it or get a new one? Can someone tell me what it cost them to fix, I won't be doing this myself I have to call someone in to do this.
moparfan77
#16 Posted : 14 years ago
moparfan77
I have a good capacitor (940nF). Good transformer primary voltage. Bad diode (~16 Ohms either direction) - just ordered from your site.. Should I replace the diode first and test, or just go ahead and replace the magnatron as well?? Is there a way to test the magnatron independently (without specialized equipment)? I don't want to short another $35 diode to test.. Thanks in advance!
GE Microwave won't heat (Microwave Repair)
Belarus nelsen2605 15 years ago
by Jim T 16 years ago
2 Pages<12
