Timmy Stanley
#1 Posted : Monday, February 1, 2010 6:20:39 AM(UTC)
Timmy Stanley
The control buttons for the oven controls will not work. The clock is on and timing. I turned the power off to the Range and now I have a PF power failure that I can not reset. Is the control board bad or maybe the push button panel?
#2 Posted : Tuesday, February 2, 2010 3:16:39 AM(UTC)
Replacement parts for WHIRLPOOL GY396LXPS01 30" Slide - in Electric Oven Self Clean | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%209761388.pdf
And a manual
https://secured.whirlpoo...da9595785256a8c0063802f/$FILE/4322525.pdf
This is going to be a pain as I do not have a wiring diagram for the switch pin-outs for the keypad so it is difficult to check and your problem could be either the control board or the keypad (control panel)
Cannot say.
So it becomes a bit of a crap shoot.
Try getting into diagnostics.
Try turning the power off for half an hour or so.
Try the following cleaning procedure.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
Perhaps someone else will jump in with a diagnosis procedure or info on which is most likely.
gman777
#3 Posted : Wednesday, March 10, 2010 9:01:06 AM(UTC)
gman777
:mad: I have experienced the exact same failureas described above. By the way the electrical schematic is taped to the bottom of the storage drawer on the bottom of the oven. So far I have
1. Turned the breaker off for 2 hrs - buttons still do not work
2. Pulled & cleaned ribbon - same result
3. Pulled all connections & reconnected -same result
4. Pulled board & checked for cold solder joint - none found
My guess is a main board failure so my next move is to study the schematic and test with my multimeter (fluke 89) and then manually jumber the relays to bypass touchpad and see if that will enable control
If it will enable control I will know i have a bad touch pad if not it will be a bad control board
Any suggestions from the pro's?
#4 Posted : Wednesday, March 10, 2010 4:25:09 PM(UTC)
gman,
Most likely the problem is a bad touch pad (aka a control panel). There is a very small chance for the control board to be bad.
Whirlpool does not provide any instructions on how to test the touch pad instrumentally. The way you are going to test the control board looks to me too risky and you can end up replacing both parts.
If you need the correct part number(s), post the complete model number of the unit.
karlr
#5 Posted : Friday, July 16, 2010 2:44:17 PM(UTC)
karlr
I have the same model (GY396LXPS01) Whirlpool and problem as Timmy. Would love to know if the cause of this problem can be nailed down, i.e. which part to buy.
